rear end
Discussion in 'The Garage' started by only 31s, Nov 30, 2004.
  1. only 31s
    only 31s 1/2 ton status
    Oct 5, 2004
    224
    mass
    got some 33s they rode quiet,but 2 weeks later my tires feel like they have huge knobbies on them. i have 156k on corp gm rear could this be my rear end starting to go ? ive checked out everthing else . /forums/images/graemlins/k5.gif /forums/images/graemlins/frown.gif
  2. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    Did you get the 33's balanced when they were installed, and are all of the weights still in place. I know you said you checked "everything" but this is an easy place to start. Are you getting any other symptoms of a bad rear end such as bearing or gear noise?
  3. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    also carefuly look at the tires for separation (bubbles in the tread)
    willow
  4. 1badv10
    1badv10 Registered Member
    Feb 26, 2004
    74
    new york
    also what kind of tires are they?? have nylon in them or are they bias ply? i've got "inexpensive" performance tires on my car and my first time driving it in the cold i thought i had a flat /forums/images/graemlins/angryfire.gif.. mentioned it to my grandparents while visiting and my gramma asked if i had nylon tires?? went and checked, sure enough they are. guess us whipper snappers dont know everything afterall.. /forums/images/graemlins/whistling.gif
  5. only 31s
    Oct 5, 2004
    224
    mass
    futura dakotas balance ok.tires ok.rims ok.when i start out avibration comes through the steering then disappears and leaves what sounds like a loud tire noise up to highway speed and winds down progressivly while slowing or stopping /forums/images/graemlins/frown.gif
  6. only 31s
    Oct 5, 2004
    224
    mass
    maybe ive asked it wrong.how bout this- what are the symptoms of a failing rear end= corp w10 bolt cover 8.5 ring gear /forums/images/graemlins/thinking.gif
  7. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Did you check your U-joints ??? Just change them if you don't know how old they are, they're cheap. Mine made all kinds of vibration and noise when they went.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Ditto , mine sounded like gear noise until I changed all the rear joints as a precaution on advice from Marv , made it go away , guess I had one bad one , must be the torque I guess /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  9. only 31s
    Oct 5, 2004
    224
    mass
    tw cv driveshaft 2months oldw/ aperfectdiff angle maybe t case causing the whine and low speed rough feel it has enough fluid and tranny shifts perfect /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have a CV also . No vibes . Yet after 9 months a u-joint was going , but I really do wheel and drive mine daily . A little noise is ok , these trucks aren't quiet . Double check everything just in case , make sure no wheel weights fell off . And with your CV , grease it often if it has zerks on it /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
