rear ext. tire mount info.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big d, Jan 14, 2002.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    for all individuals interested or who care i found a non-permanent rear tire mount that is neither costly/ugly or requires alot of work. i found it in the jeep section of a jcwhitney catalog and it is reciever mounted and best of all it ran, i think, about 40 bucks. when pluged in you cant tell unless you look close that it aint suppost to be there. only negative thing i found is itll make dropping the tailgate alittle difficult if you get in there alot. i just have seen alot of posts on this subject, so i thought id let people know.
    darrenolander
    galva,il.
    1979chevycheyenneblazer
    350/350
    gettin'down on all fours, 4 a'little
    x4 play !
  2. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Here's another one made by Reese. It costs around $75
    Just scroll down a little and you will see a picture of it.
    It says its for a fron mount hitch but, it uses the standard 2" receiver hitch so it will work out back as well.
    http://community.webshots.com/user/zepplin1976
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    If you can weld or know someone that can it would be real easy to make one of those.
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
