rear gears up front ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Obsession, Oct 25, 2001.
  1. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    I read somewhere about reverse cut gears for the for the front diff,,, what the ??? sounds like a Heep thing. Somebody help me here, can I use a ring and pinion from a rear diff in a front diff??? 10 bolt.
    Thanks for the help
    Ken
  2. 8.5 ring gear front and back same gearset between 10-bolts.
    carrier break is 2.56/2.73
    cool, huh?
    greg
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yep, Same on 10 bolts....Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  4. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    You need a high pinion center section to run the reverse cut gears. The Dana 30 fronts in YJ and some Ford Dana 44 &amp; 60s used them. You can also get them custom made.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  5. Blazin Obsession
    Sep 25, 2001
    64
    B.C Canada
    Thanks for the help
    Ken
