Rear Gears??
Discussion in 'OffRoad Design' started by Itali83, Feb 26, 2001.
  1. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I was wondering how I could find out what my rear end gear ratio is. My truck is a 87 Jimmy 350 TBI 700r4. Stock axles. Just kinda wondering more than anything else.
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    You can look at specs under coloradok5's home page, and I think there is another link that has a lot of specs. This site is under the links section of coloradok5's site. The truth of the matter is, the best and sure way to get the ration is take off the cover, drain it, and count the teeth. I have heard of another way of doing it by marking the tire at bottom, mark the pinion yoke, and turn the tire so many times to see how many times pinion yoke turns, or vice versa, then find out the ratio by simple turn ratio. Yea, sounded complicated to me too, so I just popped the diff cover and counted teeth. This is what most gear shops will tell you to do anyway. More than likely, you have 3.73, as that was common for the 350, 700r trans. Hope this helped.
    Joel
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Look in the glove box at the label that has all the codes on it, if still there. The following are the codes:
    GU2 = 2.73
    GU4 = 3.08
    GU6 = 3.42
    GT4 = 3.73
    GT5 or GT8 = 4.10
    G80 = Gov-lock
    As stated above, jack up the rear wheels, mark a tire and the drive shaft, turn the wheel two rotations and count ther rotations of the drive shaft, that will get you close.
  4. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    Thanks guys, I'll check my glove box first, because I know the sticker is still there. Thanks again.
  5. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    I got the GU6 code, 3:42's. Thanks again
