rear greasable bushings
Discussion in 'OffRoad Design' started by smokkey1, Jan 15, 2005.
  1. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    hi, I just got done swaping in all rear greasable bushings but the bushings for the rear shackles don't fit there too small for the 1 1/2 bushings that I installed. so I need two 1 3/8 bushings and was wondering if you would just sell the two. I'm going to keep the extra for replacements.
    thanks,
    justin
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, call us and we'll get you squared away. Bushing size problems are common on these trucks we do it all the time.
  3. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks, I called monday and ordered the 2 bushings.
  4. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Tell me about it, i went through three different sets before i got the right ones! ORD took care of me though and now I got the right ones:D Thanks Stephen!
  5. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    I had to go through it twice also, Steve took care of me.
  6. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well I didn't realize that I had to take out the outer sleaves out:doah: so turns out I need 1 3/4" bushings so I'm thinkin the rear springs are 1 tons :thinking: that's probably why my rear doesn't sag and sits slighty higher than the front. anyways they should be comming in tommorrow.
  7. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    What year is this truck? Mine is a '89 and it has 1.7" bushings and not 1.75", I think they said something about them being a metric size? I first got the 1.5" which were too small so I measured the spring eyes and they apeared to be 1.75 so I ordered those and they were slightly to big so I then had to order the 1.7". But anyway if your truck is one of the later years I be you have the 1.7's also.
  8. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well its a 90'. hopefully it's not the metric size.
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well I got the bushings this morning and they don't fit :doah: turns out I need the metric size bushings. so I called them this moring and got squared away they should be here on tuesday. man this was suppose to be an weekend project turns out to be almost 3 weeks. LOL
  10. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Yeah dont worry about it, these trucks are weird. I have had 4 different rigs over the years and it has never took me more than a weekend to install a lift, I pulled my '89 in the shop on Dec.1st and it is still in there! It is in driving condition now but I have a SEVERE vibration now that I think is the rear driveshaft:confused: and I only installed a 4" lift! Good luck with the bushings.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We're working on some better info to help ID the bushings in these trucks, unfortunately a 1.7 bushing is pretty close to a 1.75 so it's tough to measure them out. Moral of the story is if you have a later model truck, like '88-up, measure very carefully.
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    ok I got the bushings this mourning and they FIT. I'm so happy :D now I can got out and play this weekend.
  13. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
    Ya i instaled an entire supperlift in a day brake lines and all by my self not to mention. and had a terable driveshaft vib. i temp. took care of this by lowering the trans. case by reversing the shims. you should do this immedatly or pay the consiquence of f ing up your tail shaft.
