REAR HANGER flip for the FRONT SPRING like 52" lift ????
Discussion in 'The Garage' started by down4thakrown, Oct 11, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    if i where to flip the rear hanger for the front springs like i would be doin the 52" spring but just using my 6" supa lifts. would it affect the lift in anyway??
  2. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    The rear hanger for the front springs is already a compression setup(shackle under compression, not tension)
    Are you wanting to lower it with out changing springs?
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Are you asking if you can move the front shackle hanger forward and run 7.25" shackles to acheive better shackle angle (like you would if you were doing a 52" swap) and just running your stock 47" long 6" superlifts.
    There was a thread about this less than a week ago. I think the consensus was it can be done, but it would be a little different than if they were 52" springs.
    Mike
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    no if i were to rotate the rear hanger for the front springs like jekbrown did in his write up. if it would effect the lift. would it bring the front end down?
    if i did this: http://coloradok5.com/52springswap/rearhanger_boltedon.jpg
    would it bring the front end down???
    i know it can be done with the stock length springs, i just wanna know if im losing any lift.
  6. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    As far as I know, he didn't rotate it. I did the same thing (even using his instructions) and all it did was move the hanger forward 2.75 inches on the frame simply to allow for better shackle angle with the 52" springs & 7.25" shackles.
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    so the front lift shouldnt change much??? i dont think it will.
  8. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    You'd probably see between 0.5" and 1" additional lift, but that's simply from the longer shackles. The likelyhood you'd even notice a difference is very slim.
    Mike
  9. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i was hopin it would go down that much, i plan on flippin the shackles for the rear spings and using longer hangers. but i think it's still goin to have a saggy butt. oh well......wont be that bad hopefully
  10. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    The only to get it to go down would be to use shorter shackles, but then the spring eye would contact the frame. Same thing if you were to flip the bracket upside down so the shackle mount is higher on the frame than normal... the spring eye would still hit the frame.
    Mike
  11. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    You could always remove a leaf or two.
  12. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    its alright, im not worried to much bout it. i'll just work with the rear to level it out. maybe use some zero rates. and a some lowering shackles.
  13. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Find the thread that I started.. titled suspension suggestions/thoughts. I have the stock length springs but I moved the shackle hanger to get a better shackle angle. Lots of pics and info about actual shackle lengths and that sort of thing. The ride is 100 times better and it flexes great.
