Rear Hatch Rattle
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70Dave, Jun 9, 2001.
  1. 70Dave
    70Dave Registered Member
    Jun 1, 2001
    12
    Cincinnati,Ohio
    Rear hatch latches work fine but hatch is not tight. Strikers adjusted all the way but hatch is still loose and rattles on bumps. Did striker originally have some sort of plastic bushing on it? Or would just a new weatherstrip around door tighten it up? Any ideas? Also still looking for door caps[see other post"New to Blazers"]. Thanks!
  2. bushwacker
    bushwacker Registered Member
    Sep 8, 2000
    58
    Orange County, Calif.
    Sounds like worn out weatherstripping. When I replaced mine, the rattle disappeared.
    Bill
    72 k5 [​IMG]
  3. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Dave, on my '72 I found that when I shut the hatch I could give each corner an extra push and it would click and snug tight after that. Of course, that's not a problem now that I took the top off! (that would by my other recommendation!)
    You can't beat going Topless!
  4. 70Dave
    Jun 1, 2001
    12
    Cincinnati,Ohio
    Thanks guys. I thought it was probably compressed weatherstripping, but I wondered about the strikers as somebody previous had wrapped tape around them.
  5. highwaydevil
    highwaydevil 1/2 ton status
    Oct 6, 2000
    145
    Colorado
    I have to do the same as Ressurection. Works fine after that.
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Ditto Resurrection and Highwaydevil. I let the lift gate down slowly and make sure I hear two clicks out of each latch when I close it. Very few rattles and squeaks (I have a pretty well worn-out latch as well...).
  7. 70Dave
    Jun 1, 2001
    12
    Cincinnati,Ohio
    Thanks again. The double click trick worked great.
  8. Leinie
    Leinie Registered Member
    Mar 5, 2001
    38
    Shakopee MN
    After reading this thread, I checked mine (both) and found the problem to be - too much weather stripping - added by previous owners. All that foam would not allow the catches to fully engage to the second click.
    Thanks all - gotta love this group!
    72 K5 CST X 2
