Rear heater unit for my 1978 burb...
Discussion in '1936-Present Suburban' started by Topdown, Jan 29, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Anyone know anything about the rear heater units on the burb? my 78 is missing it and I want to replace it/make it work... I have rear air, rear heat would be REAL nice...
    -Ryan
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    On the earlier rigs (73-91 I think?) the rear heater was just a box mounted on the floor, just in front of the rear doors. It's REALLY in the way. /forums/images/graemlins/angryfire.gif It got integrated into the sidewall of the truck starting in '92. I think that the rear heater from any pre-92 model will go into your 78 pretty easily. The heater itself is an all-in-one unit, perhaps a cubic foot in size that has the blower mounted inside of it. Run the hoses to the back, hook up the wiring and a switch for the fan and you'll be all set. /forums/images/graemlins/cool.gif
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Glad I don't have that option then. On the floor???? /forums/images/graemlins/confused.gif
    Ryan, to be honest, in our climate you really won't need it if your heater puts out anything comparable to what my 91's does...........it'll run you out of the truck and the kids in the back feel it fine. /forums/images/graemlins/laugh.gif
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    On the floor????
    Yep! It partially blocks access at the passenger side barn door on my '90. What WERE they thinking? /forums/images/graemlins/angryfire.gif
    The rear air option is also MUCH less intrusive on the '92 and newer trucks. /forums/images/graemlins/thumb.gif
  5. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    If you check with LMC they sell everything but the fan itself (blades)
    And they have a really nice diagram in the catalog that shows how it's laid out too.
    There is a nifty little valve that I believe is vacume controlled to route the coolant back there as well and a blower motor resistor needed to finish it up properly. I'm not sure how that part (valve) works but I'm looking into it as well for mine. I think however I may try to cut a hole in the inner fender of my truck to sink it in so it doesn't take up so much room or mount a unit of some sort up in the overhead A/C unit with a way to keep the hot coolant from filling it in the summer when I need the A/C instead.
  6. BurbinOR
    5,829
    Oregon
    On the floor????
    Yeah, what were they thinking........... /forums/images/graemlins/confused.gif
    I've got the rear air option, but that is not really in the way.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Rear air on the later models is nearly invisible as compared to the afterthought they hung from the ceiling of our rigs. /forums/images/graemlins/thumb.gif
  8. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Yah my 91 has the rear heater what a PITA! Of course I live in a place that sees a freeze MAYBE once a year... Needless to say I dont need the damn thing. Still prety cool to have lol. My toolbox has done a fair job on the plastice cover of the damn thing sliding around back there.
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Mine isn't on the floor, but it may have retrofitted, it is basically like a long oil cooler with the right oil fittings for the water hoses that sits right in fromt of the ac evap up in the cover, works fine have heat in the winter, ac in the summer.
    89 /forums/images/graemlins/burb.gif
  10. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    I owned an 88 Chevy Van for awhile, and it had a box type unit mounted on the floor in front of the driver's side wheelwell. I'm pretty sure it was stock, although there's a remote possibility it might have been a special add on given the fact that the vehicle was an Alaska State Passenger vehicle.
    If I were gonna try to put rear heat in the back of my /forums/images/graemlins/burb.gif, I'd definitely try to find one of these van units and mount it on top of the driver's side wheelwell to keep it out of the way of floor based cargo. I would imagine the same coolant hoses could be used, although I dont remember where the connections tied into the cooling system.
