Rear hinge spring question / problem 1979 K5 blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, Apr 3, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Another 3" 1979 K5 bodylift question...
    What have you guys done to modify the rear tailgate hinge springs. They are mounted to the frame and provide torsion upon lifting the tailgate. Mine are TIGHT and I even removed them from the frame, They are now resting on the thin metal between the bumber and frame. Would it be ok to remove these and just use brute strength to shut the tailgate?
  2. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    why do you want to remove them? If the tailgate sticks when opening and closing it is probably becausee the hinges are gummed/ rusted. Mine were, I took them out, lubed them up good w/ some penetrating oil while heating them (sucks the oil into the pin). When I was done they moved freely.
  3. ChevBlazin
    Feb 4, 2002
    332
    sorry, I just realized you were questioning about the 3" body lift. nevermind
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    No problem.. no offense taken
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I cut mine and removed them... kinda tricky getting them out but a good pair of bolt cutters and some strength...
    you dont need them... just gets a little heavier to close the tailgate...
    Mine binded too... with the 3 inch body lift...
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Well I am planning on getting the airsaw or cut-off wheel after them tom. Thanks for the info I just wanted to get confirmation that I did not "have" to have them.
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I noticed no difference lifting the gate up when I removed them.
    They were such a PITA to get off I never bothered putting them back in.
