Rear interior panels
Discussion in 'The Garage' started by jimmy'sjimmy, Dec 12, 2004.
  1. jimmy'sjimmy
    jimmy'sjimmy 1/2 ton status
    Dec 22, 2001
    130
    Greenwood Village, CO
    just wondering if anyone has made their own panels. mine are so rotten that the speakers keep falling out of the panel. i had my heart set on some diamond plate panels but that is way out of my budget. any advice or pics would be greatly appreciated.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    take yours out and use them as a template. Then trace onto your material of choice and cut away. I replace mine with plywood and covered it all in carpet. Looked nice and held speakers and what ever else I wanted to bolt to it very nicely.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I replaced mine with 5/8" MDF. Works great!
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I replaced mine with invisi-panels :grin: Little more cargo space that was, and one less thing to hold in moisture and whatnot.
  5. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    diamond plate alum thin 4x8 sheet will do more than your back pannels ( the bottoms of the doors and such) thing is it only needs to be thin so that saves cost and realy when you price stock replacements the alum is cheaper im going to buy 2 sheets and make rocker gaurds as well for the outside like the crome stick on kind
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    When I redo my interior I am going to buy a sheet of 1/2" foam and trace out a long flame pattern out of it. I will then use an adhesive to hold it against a backing that I have not chosen yet and cover it completely in black carpet to reveal 3D flames! :cool:
  7. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I made a set out of fiberglass and then herculined them.
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I made mine out of 3/4" MDF and covered it in the same foam-backed headliner material that I did my headliner with. Each side holds two 6x9 speakers and a 10" sub. One of the amps is mounted inside one and there is a little cutaway where the crossover network can be adjusted. It's pretty decent, but it is definately on the low-end as far as cabinet volume goes, which makes choosing subs rather tricky. Also it adds weight. I had some pictures of it up, but they got deleted.
  9. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I took all mine out... replaced them with... Nothing.:)
  10. dremu
    Feb 27, 2000
    15,966
    458
    East of San Francisco
    I was stinking about this ... how'd you do the 'glas? Can you get it pre-gooed in sheets, or did you lay it out on a form, or ... ?
    -- A
  11. mud hungry
    mud hungry 1/2 ton status
    Oct 4, 2004
    506
    Haydenville, Massachusetts
    Where can you get the actual oem style replacments for them? anyone know?
  12. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I was thinking about doin this to mine. Have you noticed an increase in road noise with them not there?
  13. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    with mine gone you hear everything.of course i have no carpet and rusted floors.i patched them pretty good.i hear every road noise.any time a rock gets thrown up by the tires it bangs into the truck.eventually i will be making some side panels and bed liner everything.
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i'm about to do this.. i'll be using composite glass we use at the marina. comes in 4' x 8' sheets in many thicknesses.. i'm gonna use 3/16"..
    stuff is incredible.. its machine extruded and dense as hell.. ya cut it with a diamond tipped circular saw.. far better than any handlaid glass could ever be. its also what i'm using on my console..
    should be nice cuz its imperveous to water. paintable too.. we store it outdoors for years and it laughs at it.. pricey tho... i'm using some leftovers from a recent job...
    this is the stuff here.... http://www.pultrude.com/stand.html
  15. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I did this recently in my old K5. Use the factory as a template for the cuts. If you are taking out the carpet or adding the liner, use cardboard or masonite for fitment help. For the final product I used 3/16" luan that is moisture resistant. Stain and seal to your satisfaction. Next time I will probably use lexan or the like and cover it with some sort of upholstery. Hope it goes well.
  16. blazen86
    blazen86 Registered Member
    Sep 8, 2004
    55
    Virginia
    I covered mine in Subwoofer box carpet, cost was 25 buck for a huge roll of it at Crutchfield and thats all there was to it. Very cheap and looks REALLY nice. Ohh and I also added some Alpine 6x9s bolted to a small cut out of wood and then sound deadened the cardboard and the metal.
  17. jimmy'sjimmy
    Dec 22, 2001
    130
    thanks guys im going to get on it as soon as finals are over. i think im going to use MDf and cover em in carpet for sub boxes. i think i am going to mount the speakers where the ashtrays are and put a small piece of diamond plate to mount the amp. but will the MDF rot or anything?
  18. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    MDF will be alright as long as it never gets wet. Once that happens it will begin to swell depending on moisture content.
  19. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I went to a fiberglass shop and they took a peice of plywood and coated it with wax. Then they shot it with the fiberglass chop gun. Couple passes and it was like an 1/8" thick. Nice and lightweight. Then I put my patterns on there and cut them out with a jig saw. There is all kinds of different material that will work though.
    K-lite (basically fiberglass)
    aluminum
    Plexiglass would be cool if you did it right.
