Rear Leaf And Shackle Bolt Torque Settings.
Discussion in 'The Garage' started by 4wheelin4Jesus, Feb 2, 2006.
  1. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    anybody know the torque settings for the rear leaf spring bolts, and the rear shackle bolts?
    I have a 1978 gmc jimmy.
    thanks
  2. ike
    ike Registered Member
    Jul 5, 2005
    96
    orange ca
    Rear suspension torque spec
    Rear suspension ( leaf spring type)
    Spring front eye bolt 90 lbs
    Spring rear eye bolt 90 lbs
    Spring rear shackle 90 lbs
    LOL 90 lbs ... all
    This is out of a Haynes Manual Chev-GMC 76-87 Sub,Blaz,Jimm...
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    In chiltons its 40ft lbs. I have allways done this and never had a problem
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    so does mine, and the piece of paper that came with my poly bushings
  5. ike
    Jul 5, 2005
    96
    orange ca
    Torque settings
    Funny its not the same . Anyway I was going to say from the start that a torque wrench with a strict setting isn't needed in this application...If you were installing heads or setting up a bearing pre load then yes... Its good to know though so you have a idea. Something you might want to do is get a new set of crimp or metal lock nuts...what ever you call them...If not then a drop of blue locktight on each then tight with a 1/2 ratchet Just don't go crazy and overtighten so the bracket bends and squeezes and crushes or breaks... ,,,.... Thats all just IMO hope it helps...
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yes blue lock tight can be your friend. But I have never had a spring bolt losen up when not using lock tight. You have to think the tighter the bolts are the harder the suspension will have to work correctly.
