Rear Leaf Spring Bushings???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PattBlue, Aug 1, 2000.
  1. PattBlue
    PattBlue Registered Member
    May 3, 2000
    82
    N.W. Pennsylvania
    How hard is it to replace my rear leaf spring Bushings..my 90 Blazer is leaning to the Left and is CLUNKING when I stop. I've changed the U-Joints, rear Pinion and seal and greased and lubed everything and still..CLUNK!!
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    well if its leaning to the left, I'd think that your springs are sacked. And if thats the case, you might wanna check your driveshafts. make sure they arent bottoming out and running out of play in the splines. If so, that'll surely cause the clunk your hearing.
  3. istallion88k5
    istallion88k5 1/2 ton status
    Jun 20, 2000
    139
    Cincinnati, Oh
    I had this problem on my 88 K5, it ended up being the bushing on the shock it self on the rear driver side, went ahead and bought all new Rancho shocks since it needed them anyway and no more problems after that.
    If it aint a Chevy don't raise it up!
  4. PattBlue
    May 3, 2000
    82
    N.W. Pennsylvania
    Well there's new shocks all the way around..so??? Driveshaft is bottoming? The is alot of it that sticks out from the transfer case and a buddy of mine works for a dealer and gave me some "GM Special Purpose Grease" to lube up the front yoke (which has some grooves in it). I'll try that next.
