Rear leaf spring - front bolt removal
Discussion in 'The Garage' started by spearchucker, May 6, 2004.
  1. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Okay, who's got "the trick" for removing the front bolt on the rear leaf spring? /forums/images/graemlins/confused.gif
    #@*%! GM engineers /forums/images/graemlins/angryfire.gif /forums/images/graemlins/rolleyes.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The springs are pushing up on that bolts so once you get the nut off you have to drive the pin out. Use a smaller diameter screw driver and a hammer or something along those lines. That is how I did it.
    Harley
  3. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    Brass Hammer and large drift pin punch..
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Took me 90 minutes and four 12 tpi reciprocating saw blades
  5. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Guess I'm not to that point yet, I'm still working on trying to remove the nut. How did you get to it to loosen it? A box end wrench doesn't fit over the end of the bolt that sticking out. /forums/images/graemlins/confused.gif
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    A socket should, though...there's an opening on the backside of the hanger as well as that slot on the top. If you can't get a socket in there, you can always just use the open end of the wrench through the top.
    If you think just getting the nuts off is hard enough, just wait... /forums/images/graemlins/rotfl.gif
    Edit: Nevermind, you're from California, you guys don't know about rust. /forums/images/graemlins/frown.gif /forums/images/graemlins/smirk.gif
  7. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Who said I have trouble getting my nuts off /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/blush.gif
  8. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Hey you're right /forums/images/graemlins/waytogo.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
    Now why didn't I see that? /forums/images/graemlins/doah.gif
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    hahah, well even where you are the bolt may still be siezed to the sleeve! have fun if it is.... <sled trails off in a stream of unintelligible swear words>
  10. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    God I love my rust free trucks /forums/images/graemlins/whistling.gif Have not had to fight a single bolt on it once yet /forums/images/graemlins/thumb.gif Now the rusty crap I drove out here from MN is another story...
  11. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    Amen to that!!! Over and out from sunny Las Vegas...
  12. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    isnt it nice to complain that a scratch is rust,,,, arent we lucky /forums/images/graemlins/waytogo.gif
  13. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Actually it came right out. Only took about 5 mins once I was shown the way. /forums/images/graemlins/thumb.gif And here I'm missing out on all the fun that you rust belt boys have. /forums/images/graemlins/ignore.gif
  14. heavy4x4
    Aug 28, 2002
    3,270
    "Fun" is not usually the descriptive word I use...but the word I do use begins with the same first two letters... /forums/images/graemlins/whistling.gif
  15. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/rotfl.gif I knew you would read what I wrote in that way...there was no better way to phrase it though. /forums/images/graemlins/grin.gif
  16. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Must be nice, it took me most of a Saturday with a torch, cutoff wheel, and air hammer just to remove the bolts and rivets (for shackle flip) from my crewcab. The best way I found (if you have a torch, is to torch the end of the bolt off very carefully as to not damage the hanger, then pound the bolt into the sleeve a little, then torch the other end of the bolt off and push it back through till the bolt width is less than the hanger opening so the spring will fall out, then torch the bushing and pull the sleeve and bolt out together. I hope that makes sense.
