Rear leaf spring question??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Feb 17, 2004.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    My 86 K5 has 4"blocks in the rear for the lift.I want to remove them by adding a larger leaf.Thought about the shakle flip but it looks easier just to change the leaf spring.
    Does anyone know what size leaf spring I would need to get rid of those blocks.Any recomendation on what brand spring??
    What website to buy them from??
    Thanks /forums/images/graemlins/cool.gif
  2. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    What brand are in the front? Might be a good idea to get the same kind as the front so they match spring rates. And the shackle flip from what I have seen is actually not very difficult. If your rear springs are old and saggy though I would say go with new ones.
  3. Monster
    Jun 14, 2002
    68
    rancho springs up front. the old rear springs do sag a little thats why I would like to replace them. /forums/images/graemlins/waytogo.gif
  4. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Thats the same reason I went with new springs for my 4" lift, plus I use my truck to haul my dirt-bike, amongst other things and also use it to tow, so I was worried about the strength of the shackle flip.
    Maybe you should get some Rancho springs for the rear, not sure if having different springs will make much of a difference though. Probably not unless you want it to have about the same ride quality front and rear.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Several members and I just shackled flip mine. The ride is great /forums/images/graemlins/thumb.gif Seems just changing factory geometry turned my harsh stock springs into ez ridin' springs. You may need longer shocks than 4 inch lift ones as I did though. The ORD kit is strongest and your right just doing springs is easiest . But the flip is cheaper and springs can be had at any junkyard if you break or yours sag too much.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Re: Rear leaf spring question?? *DELETED*
    Post deleted by 4xcrazy
  7. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    just a fare warning,
    if you plan to swap out your rear springs plan on haveing a torch and a sawzaw ready, your bolts will likly be rusted/frozen to the spring bushings and they wont come out easy. I also recommend the shackle flip as the ride is great with it, either way though those bolts will suck big doggie doodoo /forums/images/graemlins/eek.gif
    the shackle flip is cheaper too /forums/images/graemlins/deal.gif
  8. Monster
    Jun 14, 2002
    68
    I will think more about the shakel flip.
    for the bolts on the leafs sawzaw to the rescue /forums/images/graemlins/yikes.gif
