rear leaf spring removal????l
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DALE, Mar 30, 2001.
  1. DALE
    DALE Registered Member
    Aug 27, 2000
    44
    hey guys. this morning i tried to get my rear leaf springs off.i was able to get the nuts off the shackle side ,but the bolts would not come out.the front nut you can't even get too.i have brand new springs waiting to be put in.can somebody walk me through removing my rear springs. are there any tricks to doing them or special tools. please help
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Try pounding the other side of the bolt out, or use a socket wrench and turn it while pulling out.
    90K5
  3. STV
    STV Registered Member
    Dec 16, 2000
    25
    Winnipeg, MB Canada
    I used a angle grinder with an oversized disks to cut the bolts between the leaf and the mounts. Then by new bolts. My 2 cents
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    get a bfh and a punch and just start whacking
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Sounds like the bolt is rusted to the inner sleave. WD40, Big F Hammer,grinder, highspeed cut off wheel,etc.. If you get the bolt and sleave to come out together may be easier. I asume you have all new bushings and hardware so whatever it takes to get that bolt out.......
    Good Luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  6. dyeager535
    26,982
    191
    Try varying the "load" on the bolts. Either put the weight of the truck on them (obviously have it jacked so it won't fall) and use a socket to unthread them. Either that, or adjust the weight load on them so there is as close to 0 on it as possible, and slide them out.
    Dorian
  7. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Air wrench, air compressor. Will be your best friend in this world. Don't need the fancy stuff. Harbor freight will be fine. Just make sure the tank is big enough for your wrench.
  8. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    Although i wouldnt recommend this, but as a last resort, i have heard of people using a torch to completely burn the rubber bushing out. Then you can get the sleeve off of the bolt. I had to partialy do this with a "rusty" shock sleeve.
    One From None
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Soak it with PB Blaster for a night then try it. If that doesn't help break out the torches, but try not to fudge up the hanger or shackle..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  10. rezalb
    rezalb 1/2 ton status
    Apr 6, 2000
    207
    Phoenix, AZ metro
    I cut the bolt, then got a new sleeve and bushing.....I used a BFsaws all.....have fun :)
    rezlaB
    Built for a purpose.
  11. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Hell yeah, just melt the biatch out of there. Just don't get carried away and do this to shocks cause they can explode do to the expansion of the gasses!
    Doug Krebs
