Rear Leaf Springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rob 85K5, Jan 24, 2001.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    any year 76 to 91 springs are interchangeable, Right?
    And what is the difference between the 4 and 5 leaf types? one 1/2 ton and on 3/4 ton?
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  2. dyeager535
    26,979
    They aren't ALL interchangeable....only 4wd. I've never pulled any off that I KNEW for certain they came off the year I was told, but the ones on my '86 are supposedly from a 1976 K5. I used the 3/6 combo on mine, it was 2/5. The difference in the springs from 1/2 to 3/4 is probably the spring rate or something. I can't believe that a truck rated for 3/4 ton would have the same amount of springs and rate as a K5. The way to tell is to measure eye to eye on the springs. Same length, no problem interchanging.
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    The only difference in the rear springs were on suburbans they were 56" opposed to the normal 52". I am pretty sure. Also i think as long as they are the smae length, 1/2 and 3/4 ton springs are interchangeable.
    Keep the shiny side up, and the greasy side down.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The only difference is in about '86 they started using teflon pads on the ends so the ride would be better. 3/4ton springs usually have about 8 leafs in the rear if I remember right.
    90K5
