Rear LED lights and wiring.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by keith, Jun 18, 2002.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Okay hooked up the rear LED lights and ran the wires
    LED-------------------------TRUCK
    white --------------------- grounded
    red -------------------------yellow
    black-----------------------brown
    Okay then put the front LED side markers in.2 wires.
    All running lights work
    Brakes work
    When turning on the blinker it cuts the front side marker off.
    I already installed the new electronic flasher. Any suggestions
  2. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    i run led tails, the only funky thing i noticed was the wht gruond. evidently you tapped the markers into the wrong wire /forums/images/icons/confused.gif
  3. keith
    1,158
    La Fayette, GA
    Okay how are the markers supposed to be? There are only 2 wires?
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I think the original marker lights blinked with the turn signals. If you don't want it to blink, disconnect the ground wire to the LED light from the harness and ground it directly to the body, then it should stay on solid.
  5. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Keith, is it still not working right?
