rear lift blocks, how much, where, time involved
Discussion in 'The Garage' started by swampblazer, May 6, 2003.
  1. swampblazer
    swampblazer Registered Member
    Mar 31, 2003
    49
    mass, u.s.
    hey all. i have a 88 K-5 with stock syspension, the rear is saggin a little more than the front i have 33-12.5-15's on it and i need to lift the rear 2'' with blocks. anyone have any idea on price, labor, time??? need to know soon
    thanx /forums/images/graemlins/confused.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I personally would replace the springs. Yes, alot of people use blocks, but after having blocks on worn out springs, I'll never use blocks again !!!! Being that your springs are worn out, now's a good time to consitter a real suspension lift. It all comes down to what you want to use your truck for, befor you figure lift and tire size.
  3. swampblazer
    Mar 31, 2003
    49
    mass, u.s.
    its primarally going to be a mild off road truck but i just need to do a quick fix cause it looks stupid with the rear sagging about an inch more than the front
    i am saving for a rancho 4' spring lift this summer, just need blocks for now
  4. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    You could try some zero rates. They'd lift the rear an inch or so, and you could use them with your 4" lift later on too!
  5. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    yeah, I'd go with zero rates too.
    if you are dead-set on blocks, most major lift manufacturers make them... superlift, ranch, procomp etc prolly all have what you want. Not sure how much they cost... but you could prolly find some used ones here on ck5 from peeps that have taken them off. Labor? you're gonna do this yourself... right? seriously, paying someone else to install lift blocks is silly, unless you are just rich and dont care about the $ or something. They are pretty simple to install, just get the frame up on jackstands, support the axle, take off the ubolts, drop the axle, put the blocks in, attach the axle back to the spring with u-bolts (may need new longer ones), drop everything back down and drive. retorque bolts after 50-100 miles and you're good.
    anyway, I'd highly recommend just calling up Dr. Watson over at ORD and getting a set of zero rates. He can answer any installation questions you might have...
    j
  6. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    You can get the blocks from JC Whitney for about $50 IIRC. Plus they come with new u-bolts /forums/images/graemlins/smile.gif.
  7. swampblazer
    Mar 31, 2003
    49
    mass, u.s.
    im going to do the job myself just that i wanted to know how long it was going to take. cause i know the old u-bolts are going to be junk! thanx everyone
  8. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    if you wanna make some quick work out of it..get some new u-bolts and hardware and just cut the old u-bolts right out..
  9. wadinator
    Dec 18, 2001
    233
    NW Iowa
    What is IIRC?
  10. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    If I Recall Correctly.
  11. k5blaze7
    k5blaze7 Registered Member
    Apr 22, 2002
    29
    Missouri
    we went to autozone to get blocks for my friends mazda when we lowered it and the blocks were only like 25 bucks with new ubolts so if ur gettin rancho 4 inch suspension lift this summer go cheap blocks i guess just dont get aluminum blocks cuz the WILL SHATTER easy get steel if u can but there only like 25 bucks at a part store that probably be best bet if ur goin cheap
  12. k5blaze7
    Apr 22, 2002
    29
    Missouri
    i have a ? how did u get 33's to fit with out rubbing i have a 78 k5 and i am stock hieght and runnin 31 10.50 15's and when u turn the wheel all the way there is like a hardly any clearance and doesnt look like 33's would fit wiht out shaving fenders but i know the rear will fit
    im not to worried about it though cuz its goin 6 suspension and 3 body and runnin 35's on street and what ever will fit for pleasure
    so just wonderin how 33 fit
  13. k5blaze7
    Apr 22, 2002
    29
    Missouri
    get all new [censored] and jack up the truck and get a grinder cut ur u bolts cuz THERE A BITCH to get off after so long and then throw the blocks in and put bolts in ur lookin at an hour ive done it in 20 mins but ive done it before so id say hour
  14. k5blaze7
    Apr 22, 2002
    29
    Missouri
    also ur plate that the u bolts bolt down on might not line up perfectly with the new the new u bolts so best bet is get a big ass pair of channel locks and squeeze them to were they line up and slide them in cuz that cold rolled steel is a bitch to bend by hand channel locks make it easier
  15. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    4wp wanted somewhere around 40 bucks for 3 1/2" lift blocks only.
  16. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Stupid question? Can I put blocks up front too?
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You can, its not safe. There was a blazer at work, had em up front and welded to the axle, I guess he figured they'd be safe that way. Ha ha.
  18. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    So, if I want to run 33s, and threw in 2" blocks rear and a zero rate front, would it work?
  19. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Two answers.
    Your springs are 10 Years older than his so they probably have a little more sag to them.
    Not all 33's are the same height and most arn't even really 33" tall.
  20. Corey 78K5
    13,055
    Humboldt County, CA
    NO IT'S UNSAFE AN ILLEGAL Don't cut corners when it comes to lifting Your suspention buy new front springs.
