Rear lift blocks
Discussion in 'Parts & Trucks Wanted' started by nvrenuf, Oct 2, 2006.
  1. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Edited: Looking for 4" lift blocks with NO taper.
    Anybody got any?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    just incase you do know thay are 3" springs . not are 2.5 spring width.
    i might be abile to find ya a set .
  3. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Yeah, I'm ok with the width. I still have the down style u-bolts so they should miss the block.
    If you can find a set I'd love some, just need to be sure they do not have any taper.
    Thanks!
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    thay still wont clear the down style . if any would it would be the up style with a wider top plate. think about it. the downs run over the sides of the spring and block. with the wider block it will push them apart.
    you could got 3" bend square ubolts. but thay wont seat correctly at the top of the pack. then over time thay might loosen up.
    if you need the bump stop blocks. i have a set of gm 3" with the stopper ear.
    ford 2x4 trucks ran 2.5 springs. but most of the heavyer stuff that would have had a block would be 3" springs also.
  5. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Well poo, I thought they'd clear. :doah:
    I know a buddy used some on his dually and they worked great, maybe they were off of an older, -92 Dodge. :thinking: Any chance you can get some of those?
    I have a set of 3" eared blocks but they're not quite tall enough to make the truck level. To make them work I'd have to stack some extra springs and I don't have another matching set to use.
  6. sweetk30
    Nov 1, 2004
    25,526
    526
    will see what i can do.:wink1:
  7. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    I've got a set of 4" flat blocks from my 95 F350, but as discussed,they are for a 3"wide spring. I also have the u-bolts from said truck,with a sterling rear (3 3/8" axle tube--like a 14FF). If you think they might work for you, let me know.
    Jimbo
  8. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    That's for the offer but I've got to stay with my current u-bolts to retain my sway bar.
    This may be more difficult than I thought... :thinking:
  9. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Edited original post.
  10. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    one more time,what size are you looking for??
  11. sweetk30
    Nov 1, 2004
    25,526
    526
    he needs 4" lift no taper. ear on sides for bump stops. and best if 2.5 wide springs.
  12. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    TTT, edited first post - whatcha got? :ears:
