rear lift blocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by baldk5, Mar 31, 2002.
  1. baldk5
    baldk5 Registered Member
    Jun 3, 2001
    29
    nova scotia, Canada
    Hi, ive been away for a while, i just bought a new house and my internet access has been limited. I have a question about something that has already been answered but im gonna ask anyway. I lifted my blazer 4" using tapered blocks in the rear. I have 10 bolt axles and i lengthened the rear driveshaft. My problem is that the rear u-joints are running at a crazy angles.I have to replace the driveshaft soon, but before I do that (heres my question) what is the best/cheapest way to fix my u-joint problem? I forgot to mention that i have a 700R-NP241(its a 1990). Any help will be appriciated, thx.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Lower the Tcase. Also you said you put in tapered blocks. That should have helped your drive line angles, unless they got installed backwards. If they are installed backward they will hurt your angle.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Your angle shouldn't be bad with a 4 inch. What brand of lift did you install. Maybe your blocks are backwards if your angles are really bad.
