rear lift springs
Discussion in '1936-Present Suburban' started by roadhouse66, Aug 6, 2002.
  1. roadhouse66
    roadhouse66 Registered Member
    Dec 6, 2001
    24
    Sanford, MI
    Hey guys getting read to do my lift and axles on the Burby. I bought some slightly used 4" front springs with new Rancho shocks and steering arm off a buddy. He didn't have the 4" blocks for the rear, and my stock springs and bushings are soooo bad back there I wouldn't want to do a shackle flip either. I want to get some good 4" lift rear springs....who has the good ones at a good price? Will 4" springs in the rear still make the Burby sit ass low? Should I go with 6" springs in the rear? Thanks for the help.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    With my 4" four spring Rough Country lift the rear actually sits a little higher than the front. /forums/images/icons/smile.gif
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I know a guy who put 6" springs on the rear of his burb 6 months ago and the back still sits higher with no sag. I bet the 4" would look level.
  4. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    MYSELF I HAVE A 6 INCH FRONT AND REAR AND MY TAIL IS STILL THE SAME AS WHEN i INSTALLED. I USED SUPERLIFT SOFT RIDES IN THE REAR AND IF IT EVER SAGS I'LL BUY A 1 IN BLOCK KIT. /forums/images/icons/grin.gif
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    My truck came with 4" Rancho springs up front, and 4" blocks in the rear. It sat level, until I started towing, so I put 6" Tuff country springs on the rear. It sits about 2" higher in the rear, but when I have my boat on the back, and all my coolers in the back it sits level. I am getting ready to step up to 6" in the front and 8" in the rear so I can run 38s . I will find out how it tows then /forums/images/icons/wink.gif
  6. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Dan, mine tows fine with 38's and 6" suspension/2" bodylift. If you're getting Super Swampers get the TSL Radials. That's what I have.
