Rear lift?
Discussion in 'The Garage' started by jess, Mar 16, 2004.
  1. jess
    jess Registered Member
    Jan 4, 2004
    27
    CT
    Going with a 4 inch lift and a lot of trimming. Is rear ORD shackle kit the way to go over 4 inch springs in the rear?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes deffinately. you will use your stock springs and be a much smoother ride than lift springs. /forums/images/graemlins/waytogo.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Shackle flip all the way! /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Everybody talks highly of the shackle flips, yeah they might be a better ride due to using the stock springs, but in my opinion, I personally think they make the rear of the spring hang too low in the rear. I have seen a few rigs with these flip kits, and seen some banged up from hitting on rocks when wheelin or whatever. I personally am going with the spring lift as I kinda need the extra stiffness in the rear anyway. (hmm, that didn't sound right /forums/images/graemlins/thinking.gif)
    Anyway, I would look around before jumping to any conclusions and take alook at other peoples rides and see what you think of their setups.
    AGAIN,, just my opinion. /forums/images/graemlins/waytogo.gif
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't think its that bad if you run the stock shackle and flip it. Aftermarket shackles may take some damage but with factory shackle and springs obstacles should slide on spring and not hit shackle. I think you were meaning Jay's shackles , right? He has a set with dual holes and the extra hangs down. Oh well , I like the ride of both our trucks and the method of lift is entirely different /forums/images/graemlins/waytogo.gif
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI, Shackle Flip, and Towing are not reccomended !
  7. 4xcrazy
    Oct 31, 2003
    9,472
    5
    And supposedly is not recommended with lifted springs either,,,,, /forums/images/graemlins/thinking.gif
