Rear Main - Help
Discussion in 'The Garage' started by pvfjr, Aug 15, 2004.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Anyone feel like giving me step by step instructions on replacement? Or at least some tips? I have to be able to drive into the base shop, fix it, and drive out. I can't afford any complications. I've never even taken off an oil pan before, so I don't know what to expect.
    Also, can I use this for an oil pressure guage?
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Re: Rear Main
    I did the rear main repair in my garage on base housing. It is not that complicated, althought when I tried to take my oil pan off I had some problems. I think the PO had used liquid nails to hold that thing on there. Tooke me a while to get it off and when I did I ended up buying a new oil pan.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Re: Rear Main
    No you can not use that as a port for the oil pressure sender. That plug is used to drain the coolant from the block.
  4. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Re: Rear Main
    Are you sure there's coolant there? Being so close to the oil pan and all, it looks like it just goes into the case.
    And I would do this in my garage at base housing, if I had one. Unfortunately I actually live in the dorms, with no outdoor space to call my own whatsoever. They'd nail me if I tried this in the parking lot.
  5. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    Re: Rear Main
    i don't know what the plug is but it is entirely possible that it could be for coolant, that stuff runs all around the block.
    take a bud with you, have him take his ride just in case you have to run out and get something.
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Re: Rear Main
    Anybody have any advice as far as replacing the seal?
  7. readymix
    May 30, 2004
    6,706
    26
    Re: Rear Main
    yes i am sure about the coolant.
  8. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Re: Rear Main
    If you are looking for a spot for an oil pressure sending unit there are plugs on the top of the block near the distrbutor. That is the block drain plug that you have shown
  9. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Re: Rear Main
    Ok, the plug question is answered. So what about that seal? /forums/images/graemlins/dunno.gif I would feel better venturing into the great unknown if I had some advice or instruntions.
