Rear main oil seal
Discussion in 'The Garage' started by rcamacho, Jul 21, 2004.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Apparantly the rear main seal is blown on my 427. I believe the block has the older 2-piece seal and a 7qt Moroso pan. Q: how much of a PITA is it to replace the seal?
    The local reputable shop wants about 4 bills. I'd do it normally but I don't have lift equipment and my time is limited through September.
    I'd like to get this done before the clutch is totally ruined. It's not slipping yet...
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you have to drop the pan and remove the rear main cap. then just push the old seal out and put the new one in.
    as for having a lift, ive removed the pan on my truck a few times, and my truck is stock height. mines only a SBC though
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    From memory, there are rope and rubber seals. Any preference from the group?
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    never heard of the rope seals, i always use the rubber ones, felpro brand. /forums/images/graemlins/waytogo.gif
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    Does the transmission need to be dropped to push the upper seal in, or can it be pushed in from the crank side after the pan is removed?
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nope the tranny can stay in place. just take a small rod or pick or something and just push it around. one it sticks out enough grab it with something and pull it the rest of the way out.
    when you put the new one in, use the inside seal protector (comes with seal) and push the seal around the crank.
  7. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks!
    Now to decide if I'm ambitious enough to try it... /forums/images/graemlins/thumb.gif
  8. rcamacho
    Jul 1, 2004
    1,324
    WA
    Well, I had a local shop replace the pan gasket and main seal. Unfortunately it's leaking like a sieve now. ARRRRG! /forums/images/graemlins/angryfire.gif
  9. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Where's it coming from?
  10. rcamacho
    Jul 1, 2004
    1,324
    WA
    Main seal again. The shop is taking another look.
    Q: are there oil gallery plugs at the rear of the block?
  11. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    Yes, there are three at the rear of the block behind the flexplate/flywheel(allen head pipe plugs usually)--also a freeze plug at the rear of the camshaft that seals the rear bearing for the cam that seals oil in,not to be confused with the two other freeze plugs next to it that go in the water jacket(cam freeze plug is the one in the middle). Cant say I've ever seen those plugs leak though,changed a lot of them at the machine shop but never saw one leaking,but who knows?? /forums/images/graemlins/crazy.gif
