Rear main seal...Help!!!
Discussion in 'The Garage' started by fjleiter, Jan 30, 2005.
  1. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    Building a motor for my 1990 K5, bought a "race prepped" block from a place in Michigan. Got the block but needed freeze plugs, cam bearings etc... Which are all done now. Only other thing it needed is the rear main seal "carrier".
    It's a 90 Vin K one piece rear style block. I found a carrier on Ebay but without a reference part, I am not sure if it will fit or not. Can anyone look at these and tell me if they will fit or not?
    1) http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7950215084&ssPageName=STRK:MEWA:IT
    2) http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7950961722&ssPageName=STRK:MEWA:IT
    Thanks!
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i think thay are all the same and the first one has all the studs and nuts for the pan end. less for you to get later.
  3. fjleiter
    Feb 13, 2004
    278
    Palmyra, NY
    My main concern was that the block I have has a stud on one side and a dowel on the other, the dowel looks like its a larger diameter than the stud and the seals in the auctions look like the holes are the same size...
