Rear Main Seal in T-Case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WakeBoard&4X4er, Apr 4, 2002.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    How hard is it to replace the rear main seal in the 241 t-c. I was under my truck last night putting in a new starter, and could see that it was leaking.
    Any input woud be Great!!
    91k5, 350, 241 T-C, e-700, (no mods) 4 inch lift, and drive shaft was never leghtend the drive shaft, and the seal was replaces about 2 years ago, when i bought the truck
    /forums/images/icons/crazy.gif
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    It is easy. Just pull the driveshaft, pop the old one out(becareful not to pry against the housing or you can break it) and tap the new one in. One note, those seals always leak. That seems to be how it stays lubricated. I replaced mine before my SYE and it didn't take long to start leaking again.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep. I replaced mine in my 208, and it was easy. But it started leaking again not to long after. I have heard if you put some RTV around the seal to case mating surface this helps some.
  4. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Sounds like after sitting for 3 days and only a little spot it is not somthing i need to worry about it right now.
