Rear main seal leaking?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Sep 27, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Changed my oil today, and noticed the bellhousing, starter and a lot of stuff in that are was covered with oil...would a leaking rear main seal cause this? The tranny shop replaceed that seal when I got the tranny rebuilt...so it looks like they might do it again.....
    90K5
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I would either be the valve cover gaskets, back of the intake or the rear main seal. Look at the beack of the valve covers and see if they are leeking there. It will make it apear that its leaking from the rear main seal.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I had oil in that area on my S-Jimmy. Turned out that one of the lines to the oil cooler had a slow leak. You'll have to get under there are look really closely to find the true source of the leak.
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    my starter got covered with oil and it turned out to be the pan gasket and the oil dip stick tube.
    I took the dip stick tube out, cleaned up the block hole, gooped some Black sealant on it, and stuck it back in. Replaced the pan gasket (and did the rear main at the same time because it is a 2 piece --- easy to replace with the pan off) and my oil problems went away.
    Also, the valve covers are a good thing to check. A lot of times the back of them will leak down the side of the block.
    Good luck,
    Thomas
    -- '84 K5 Blazer --
    <a target="_blank" href=http://stoopalini.off-road.ws/blazer>My Blazer Site</a>
