REAR MAIN SEAL ON 82 6.2L
Discussion in '1982-Present GM Diesel' started by josephn, Sep 17, 2001.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    I AM LEAKING PRETTY BAD FROM MY REAR MAIN SEAL.
    IT LOOSES ABOUT A HALF A QUART A DAY. MORE WHEN IT IS PARKED UP HILL.
    HOW DIFFICULT IS IT TO REPLACE IT?
    DO I JUST DROP THE OIL PAN AND PULL THE REAR MAIN AND REPLACE IT OR DO I HAVE TO DO ANYTHING SPECIAL?
    THANKS.
    1982 6.2L Diesel K5 Blazer, TH700, 31 inch tires.
    Fire ALWAYS makes it better.
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Pretty much. Drop the pan, loosen up the main caps, remove the rear main, use a pick and/or screw and pull the seal out. Originally '82 6.2s had a rope seal, i believe this can be replaced with slightly better two piece neoprene style use '85(?) on up.
    Real trucks don't have spark plugs!
  3. josephn
    Nov 3, 2000
    138
    Utah
    Cool thanks.
    I never thought about using the normal neoprene seal instead of the roap one. Can you really do that? If so do i just ask for an 85 rear main seal instead of an 82?
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I just did this last winter so the process is still pretty fresh in my mind if you have any questions. I do remember that I got the seal at Advance Auto Parts. It was made by Fel Pro and was about 20 bucks. It was a two piece rubber ( or some similar compound ) seal. Me and others here who have done this before can talk you through it. Its not as difficult as you may think.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
