rear main seal Q
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Apr 10, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Went into AutoZone to price the rear main seal, 76 K-5 350, they said there were 3 different seals for it, single lip, doulble lip and no lip.. any ideas?? The truck is my only vehicle so I really can't pull the seal then go buy one.. Thanks..
  2. The 74 chevy I used to own had a 4 bolt main block with the double lip rear main seal in it. Since you are going to have to take the oil pan off to do the rear main seal, you should invest in the Fel Pro one piece oil pan gasket. It makes the job faster and you install it dry. I got mine for $34.99 at my local auto parts store, but you might find it cheaper where you're at.
    Later...
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Most engines use the double lip seal. If you want to make sure you have the correct seal then just buy all 3 and return the 2 unused ones. I used the 1 piece pan gasket before and it is sweet. It makes things a whole lot easier especially when doing it in the truck.
  4. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Just go to NAPA and get part # JV603. The only choice you should get is rope or teflon seal. Get the teflon or rubber seal.
  5. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Thanks guys.. I have already planned on the Fel_pro pan gasket!! It is a sweet gasket..
