Rear Main seal replacement on 1 piece rear main motor???
Discussion in 'The Garage' started by sled_dog, Mar 9, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    How is it done? I may be doing an ultra fast motor pull this weekend to replace my flywheel on the burb. And while doing it I might as well fix that badly leaking rear main seal. So whats it take to replace one of them on a 1 piece rear main motor? Do I have to pull the whole damn crank or can I do it by simply dropping the pan?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I got my first look at a 1 piece rear main block and there is a 2nd cap on the top side of the rear main, so once the flywheel is off you should have to pull the top cap, and the oil pan and lower cap.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I simply pryed mine out and tapped in a new one when the transmission was out being replaced,,, /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
  4. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    They are simple to take out, but getting them on is a headache. Be sure not to damage the seal when your working it on. They may even sell special install sleeves to slide it on.
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Yeah, don't forget to spit some oil on the rubber before you slide it on your crankshaft,,, /forums/images/graemlins/whistling.gif
  6. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I thought I would say the same thing everyone else said. It is really easy. I've done two. Some oil and the install sleeve mentioned above make it smooth. /forums/images/graemlins/pimp1.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    As everyone else said, just pry the old seal out being carefull not to nick the crank, then install the new seal. Use the teflon seal, it is much better than the factory rubber seal. The teflon seal I just installed for someone even came with an install sleeve.
