rear main seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mccomas, Mar 31, 2004.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    when i replace my transmission next week, i want to replace the rear main seal. do i need any special tools to get it out or back in? any tips...
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    that should be a one piece rear main, hardest part is getting it out
    pull trans, pull flywheel/flexplate, now the fun part, I have had luck drilling a real small hole in the steel shell of the old seal, then threading in a screw, then prying on the screw with 2 pry bars until the seal pops out
  3. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    You take off the trans, flexplate, and you got to drop the only pan. Then unbolt the part that holds the seal and replace the seal, you probably need a new gasket too. Be very gentle when putting it back on, use assemble lube or atleast some oil on the seal when you reinstall. Like above, I guess you can try and do what he said so you wouldn't have to drop the oil pan and buy a new pan gasket. Good luck.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    If it's a one piece seal you don't need to drop the pan, i replaced mine without dropping it when the trans was out, i simply tapped mine out, got it to where it wasn't straight and just kept tapping and pryed and it popped out. Then oiled up the new one and reinstalled it. /forums/images/graemlins/thumb.gif
  5. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    If it's a one piece seal you don't need to drop the pan, i replaced mine without dropping it when the trans was out, i simply tapped mine ont, got it to where it wasn't straight and just kept tapping and pryed and it popped out. Then oiled up the new one and reinstalled it. /forums/images/graemlins/thumb.gif
    Damn, that blows /forums/images/graemlins/doah.gif
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    On the 86?? shouldn't that still be the old 2 piece rear main?????
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I think there may of been some leftovers installed, but for the most part 86 was onepiece seal. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    86 is 1 piece seal, my engine is an 86.
