Rear main seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wishbone, Mar 16, 2006.
  1. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    Mine has developed a leak. Not terrible but it is putting some oil on the driveway. I don't think I can change that myself. Is that something I can let go for a while or do I need to address it now? How much would that cost me?
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    What year rig? The two piece seals can be changed by dropping the oil pan and removing the back main cap. The tranny needs to be removed on the one piece seals.
    Depends on how anal you are if you need to fix it or not...
  3. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Thanks for the reply. It's an '84 with 350. A local shop quoted me $400 to change it which seemed a little steep. Is a two piece easier to install than a once piece? The oil pan I can drop myself no problem. How hard is the back main cap?
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    If the motor is sitting on the ground, the one piece is easier. I have seen two different types of two piece seals. Get the rubber type, it's easier to install. The rear main cap is fairly east to get to and remove. You just need a torque wrench to reinstall... I'd say it's a four hour job for an experience mechanic...
    dp
