Rear main seal
Discussion in '1982-Present GM Diesel' started by Swanson52, Apr 2, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Has anyone had any experience changing the rear main seal on the 6.2? I have an 83 K5 with the 6.2 and the rear main is leaking like a sieve. Never torn into a diesel, and I am curious as to what I can expect.
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    If you have ever replaced a rear main on a small-block gasser, it is exactly the same. Just drop the pan, and replace the seal. Your '83 will have a two-piece seal. If it's original, it will have a rope-style seal. The newer seals are much better.
    Good luck.
    Casey
