Rear panel replacements
Discussion in 'The Body Shop' started by mud hungry, Mar 19, 2005.
  1. mud hungry
    mud hungry 1/2 ton status
    Oct 4, 2004
    506
    Haydenville, Massachusetts
    Has anyone replaced the entire rear outside panels on a 84 blazer. what kind of work are we talking about. and does anyone have pictures.
    thanks
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    you mean.... like this???
  3. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Is there a reasonable way to just remove the outer skin of a rear quarter panel. I have a 85 parts truck I was going to steal the quarters from to fix the PO's hack job on my 79. The front clip seem to be very straight forward. I have a spot weld cutter and grinder, I just need to know where to look for the seams and what to watch out for. Thanks.
  4. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    It might be easier to remove the whole 1/4 if you can. It unbolts on the rear and around the wheel well. The only spot welds to drill out are on the door jamb, and on the inner side of the B pillar.
  5. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    Thanks for the reply. The parts truck is just a shell, no engine, trans or diff. I had to chop up the fiberglass rear roof so it would fit in the storage unit I am forced to work in (stupid condos). If the welds are just in the door jam and B pillar this will be very do-able. Thanks.
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    It's also spot welded along the floor and rear pilar where the tailgate latches to. Not that difficult to take off, just take your time. Also there's a lip that slides up into the B-pilar about 3/4 of an inch or so. I don't know if that will effect you, but it was in my way when I put a new side panel on.
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I forgot about the top of the B pillar. Mine was only welded to the top of the 1/4. I drilled the 3 spot welds and pulled the 1/4 down and out. I had no welds in the back. It was bolts only.
