Rear Pinion Angle ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zepplin, Oct 31, 2000.
  1. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I already have Skyjacker rear 6" springs and plan to use it with the rear 4" shackle flip. Will the shim from the rear springs be enough or will I have to install a larger degree shim?
    Dazed and Confused in a 74 Blazer
    Zeppelin
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Are you saying that you're going to have 10" of lift? Are you going to use a CV driveshaft on the rear? I would think the shackle flip would help tip the pinion up a bit, but I guess it also depends on the arc of the springs at the pad.
    Rene
  3. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Yes, it will have a 10" lift I have a set of 38.5 TSL, as well as a 14 ff rear that I have from a previous truck. I do plan on using a CV driveshaft though. So, the shim that came with the rear 6" springs should be enough with the shackle flip?
    Zeppelin
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Well I could be wrong but I've heard that with a CV driveshaft the pinion should point directly at the transfer case, so there is a 0 degree operating angle at the diff. I would probably angle the diff down a bit from that, to compensate for movement on acceleration. So I don't know if the shim you got will be enough. Is it a 4 degree shim? I'm currently using a 4 degree shim with a 4" lift and a regular driveshaft. I should probably have only a 2 1/2 degree shim but I don't have any bad vibes and my U-joints seem to last so what the hell. Anyways with the 4 degree shim I have my diff is almost pointing at the T-case.
    Rene
  5. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Thanks, I believe it to be a 3 degree shim so I may need another degree or too. Thanks again.
    Zeppelin
