Rear Pinion Nut on 14 Bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, May 23, 2000.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I tried and tried and cant seem to budge it. I tried an impact, I tried a breaker bar with both my feet. I have the truck up against a wall with the E brake on, so theres nowhere it can roll when I try to get the nut off. I just cant get the sucker off. Any suggestions??
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Not sure just a thought.But is a left hand nut.Never done it before so couldn'e be sure.
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I've had to use a 600 lb impact to remove one before.
  4. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Maybe you need a bigger breaker bar. You're probably already using a huge one, but I just was curious. I have a 15 inch bar that I used to use all the time. I thought it was great until I got a 25 inch one a couple weeks ago from Harbor Freight tools. Man, another 10 inches made all the difference in the world. (Thats what SHE said) hahahaha. Sorry, I had to say it.
    Whatever you do, good luck.
    '73 K5
    Chevy good...Ford bad
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Some peolpe use RED Loctight, I think it needs heat to come loose.
    Good luck
  6. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Use the longest breaker bar you own and then slide your floor jack handle or high lift jack handle over the end of it. You will need 4'-5' of leverage to get this nut off. If you are a small person you might need a longer lever. How are you keeping the yoke from spinning? I put a huge pipe wrench on it with another pipe over it's handle and wedged it against the ground.
    CB
