Rear power window from Suburban?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, Aug 9, 2002.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I found a rear power window motor and all the associated parts from an 82 Suburban. Will it work in my 87 K5? It looks like it will bolt right in but I am not sure if they are the same. If they are different, will any of the burb parts be usable so I only have track down the unusable parts?
    Any response will be appreciated :-)
    Rolled
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes everything will bolt right up...everything from a 75 - 91 will bolt right up.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I am not certain about the inside guts but the window ABSOLUTELY WILL NOT fit the blazer tailgate.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    My turn to chime in....NO IT WILL NOT FIT.....reasons are:
    Window is too wide thus window channel is too wide as well
    window scissors aren't too big and will bolt in but the window motor/regulator bolt directly to the scissors and it is too wide for the tailgate, notice a burban gate is a bit wider in width.
    Here is what you can use:
    All wiring, switches, tailgate key switch
    Window scissors but not motor and regulator need the gearing and regulator seperate or "remote" and connected by a drive cable
    and thats about it....
    Hope I was of help.
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I have an Electric tailgate for your K/5.Out of an '87 and I'm in Phoenix,Az.Send me a PM or E-mail me.Mike
  6. GMCFIRST35
    GMCFIRST35 Registered Member
    Dec 2, 2001
    38
    LARAMIE,WY
    I HAVE TRIED TO INSTALL A POWER REAR WINDOW MOTOR IN MY BLAZER FROM A SUBURBAN ANDIT WILL NOT FIT THE MOTOR HITS ON THE SHELL OF THE TAIL GATE IT WILL NOT FIT AT ALL
  7. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks for the help guys! Glad I asked before I purchased the parts.
    BLUESMAN - Check your PM.
    Rolled
