rear power window help needed
Discussion in 'The Garage' started by BranndonC, Apr 26, 2002.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I just got my first blazer and the rear window works from the front switch, but the key won't work in the tail gate to roll it down, is it easy to fix this? And yes, i did get the key for it, it's round
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if the key fits then it sounds like a bad wire or rear switch
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    would it be easy to fix myself?
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    as long as you know somewhat what you are doing yes it should be easy
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I have the same problem, just too many higher priority problems to get to this one... I guess switch, too.
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> Not necessarily ....... I bought a whole new switch assembly and it still doesn't work ...... there's something in the wiring if you ask me ....... it's a fairly common problem ...... I too ahve no time to dig into it, but I do have a nice wiring diagram for the rear window somewhere ...... If you want, I can try and find it to give you some help ?
  7. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Is that something that is already or can be scaned I would also like it to use to convert mine to power thanks riz...mike
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> It's a hand drawing by somebody else here ..... I got it a while back when I posted about my problems .... It's in color and shows where the wires go and what they're for ...... I'll find it tomorrow ..... I'm going to bed right now ....... I threw out my back yesterday and I need to get some ice on it .
  9. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Hey Riz, if you're sharin' the wealth, would you send me a copy too?
    Good luck with your back!!!
  10. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I did a rough computer drawing of the wiring. I had passed it around for awhile if its still needed I can send I may even still have a webpage up with the diagram on it. I converted everything over from manuel to power myself and was very happy with the results its not all that hard. If you have any questions feel free to ask. A simple volt meter makes this project that much more simple. Since I am not near the end of hiding the wiring and all I may consider a write up on it. Sound interesting?
    Sounds like the key switch is bad in your case brandonC my local lock smith rebuilt my assembly for $15
  11. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> I think you're the one I got it from ........ I've looked and can't find it this morning ........ I guess I'll need it again too.
  12. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ever find the diagram?
  13. BowtieBlazer
    Jul 15, 2001
    2,462
    I've got it...hehe...I made it...E-mail me @ JTEKEL1@LSU.EDU and I will send it over...I am at work now but I can get it out by mid afternoon
  14. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    This may have been covered already. I replaced the switch, needed to have 3 keys then, but thats ok. then the wires went bad later and replaced those too.
  15. BowtieBlazer
    Jul 15, 2001
    2,462
    I got my key switch on teh tailgate rekeyed to match my existing door lock keys..cost $15
