Rear Power Window Motor Replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eshorvath, Aug 13, 2003.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    I have found that the power seat motor from GM vehicles work awesome for replacing the worn out rear window motor on the Blazer. You can find them in the junk yards under the driver seat. You would be very lucky to find a motor in the rear tailgate of a blazer anymore. Has anyone else tried this?
    Eddie
  2. dyeager535
    26,979
    Nope, haven't tried it, but I guess it should work.
    How do they mount to the tailgate, and what years/applications for donors?
    I've had the tailgate motor apart before, but I can't recall how it's mounted to the tailgate...is it a simple swap?
    How about the speed/strength of the motor? Equivalent to the tailgate motor?
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I'm also interested in this as my tailgate window motor just recently crapped out on me. My main concerns would be mounting, speed, and reliablility/life span of the motor. Thanks!
    Kris
  4. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    The one I used was a 73 Cadilac. Same mounting, BUT the power cord comes out the opposite side as the Blazer does. There are two bolts that hold the stock one in, and the Cadi one has one, so I tapped the second hole. It is as strong, if not stronger, (remeber, it lifts heavy drivers) but the one I have is a little loud.
  5. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    The one I used was a 73 Cadilac. Same mounting, BUT the power cord comes out the opposite side as the Blazer does. There are two bolts that hold the stock one in, and the Cadi one has one, so I tapped the second hole. It is as strong, if not stronger, (rememeber, it lifts heavy drivers) but the one I have is a little loud.
  6. Greenie
    Greenie Registered Member
    May 11, 2003
    28
    Glendale Arizona
    I got mine from my local parts house. Had to order, but the name is Cardone, I think. Check it out. Piece of cake to install.
