rear power window motor replacment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by timebomb1602, Mar 30, 2001.
  1. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    hey has anyone ever replaced the rear power window motor on a 91 jimmy? any tips would help greatly!!!!!
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Very simple job...............From inside the truck, with the rear window in the up position, take off the tailgate access cover(18 or 20 screws). Disconnect the power to the motor. Disconnect the drive cable from the motor body. Unbolt the motor from the bracket- I believe there's 2, maybe three bolts/screws. Take off the old motor and install the new one in reverse.
    While everything's apart, it's worth it to spray some graphite lube down the cable tube and inspect/lube the drive gear.......
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Before you buy the motor, make sure that's really the problem. The back window in my '87 moved at a glacial pace when I bought the truck. When I opened it up to see what was going on, I found that the cable between the motor and the window regulator was all gummed up. The factory lube had dried out. $13 later I had a new cable and the window worked like a champ!
