Rear Power window problems again
Discussion in 'The Garage' started by TxK5Blazer, Dec 10, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I now have lost all power to my window it won't roll down inside or outside. I started at the tailgate and found the wires running out of it. one orange one blue and one grey it looks like...the orange is by itself and the other two are together. there is a plug just under the tailgate I took that plug apart and I am getting now power there. Question should I be getting power there or not? I also looked in my fuse box and none of them are blown. Is it a regular fuse or one of those silver breakers I think they are. This sucks I can't get to my tow ropes or my spare or tools that are backthere. Please help ASAP.....Jason
  2. dyeager535
    26,975
    Sounds like the switch in the tailgate is bad, the one that cuts power to the mechanism if it "thinks" it's unlatched, thus open.
    You can find that switch by unbolting the access panel, and reaching up into the drivers side top corner of the tailgate. The wires plug into that switch. You can "jumper" the two wires going into the switch. That will give the mechanism power all the time.
    I bypassed mine on my old truck because it failed, just can't let anyone else thats dumb drive the truck, or forget when your tailgate is down. /forums/images/graemlins/smile.gif
    Re-reading your post, are you or are you not getting power to that plug underneath the tailgate? I can't tell if you mean no, or that now you are getting power there.
  3. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    2 weeks ago i cut out my sensor and it has made all the difference in the world!!! /forums/images/graemlins/thumb.gif
  4. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I am not getting power to that plug under the tailgate ....Jason
  5. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    TTT please guys I am stumped on this one I really am counting on you guys to see me through this....Jason
  6. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    should be a silver breaker on top right I think, Is there power at the front switch?
  7. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I don't think there is power to the front switch because it does not work either....Jason
  8. gotmud?
    Feb 23, 2002
    1,172
    up north
    pull that front switch and check though. If there's power there then it's a bad wire from there to the rear somewhere, check just before the blue wire goes goes into the tailgate where it splits in 2 cut that old splice out and redo it, worked for me once when mine quit working on both ends.
  9. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    never pulled the switch out how do I go about doing it without breaking the switch apart....Jason
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Easiest way to pull the dash switch, is to pull the ashtray to get to the nuts that hold on the plastic trim around the switch and the switch itself.
  11. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I emailed you the wiring diagram, should help.
  12. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Thanks Alec that does help...Jason
  13. laketex
    laketex 3/4 ton status
    6,220
    North Texas
  14. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    HEY!!! WHOA!!!! STOP!!!!!
    B4 you tear the dash apart, check the wires where they go thru the firewall. On my 'Burb I've had the plug there work loose twice. Kills power to the rear plug and nothing works.
    I also elim'd the closed tailgate switch. Wouldn't go back up in Ensenada and that was enough of that ol crap. On my '79 the switch is on the pass side latch.
  15. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    where would that plug be located at in the firewall....Jason
  16. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Man you were right about the plug on the fire wall I was under the hood today and was taking off my K&N to clean it after our run yesterday got kinda dusty. well I noticed that there was a plug out and wondered what the hell is that. Then I remember your post and look at the wires same color as the ones in the back. Wow now she works from outside and inside. Thanks so much I owe you one man...Jason
  17. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Glad that was an easy fix.
    Mine is btwn the steering column and the driver side exhaust manifold.
  18. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Mine was located on the fire wall right behind the driverside head...Jason
