Rear Power Window problems
Discussion in 'The Garage' started by TxK5Blazer, Dec 1, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I did a search and found some info but I have a different problem. My window rolls down from the rear with the key but not the switch on the inside. What might be wrong and how do I go about fixing it.....Jason
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I'll email you a wiring diagram from a '78. Its basically the same but there may be a black wire included in the harness that is a ground (you'll either have four wires going into the tailgate or three wires). I think the easiest place to check is power into the switch on your dash. If you have power there then check the up and down power coming out of the switch while the switch is in said position. Once you find no power, work up the line.
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Funny thing is it was working then stoped all of a sudden yesterday. we were getting out of the den and headed home and I was rolling up the window and it just stopped so I turned off the truck got out and went to the back and it worked rolled right up. The switch inside won't go up or down....Jason
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Check the wiring that runs down the frame rail to the tailgate. Mine did the same thing and I found out that a couple of the wires had worn off the insulation and shorted out /forums/images/graemlins/eek.gif Works fine now /forums/images/graemlins/thumb.gif
    There is also a relay mounted on the firewall(pre 81 models, 81 and up the relay is in the fusebox), check that /forums/images/graemlins/thumb.gif
  5. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Hello
    im having a problem also
    with the key it goes up and down
    with the switch it only goes down not back up,
    any idea's?
    please send me the file also
    Thankyou
    k54x4@cinci.rr.com
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    You have mail /forums/images/graemlins/thumb.gif
  7. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    Thanks Muddytazz
    got it il check it out,
    this week
    Thanks again
  8. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Mines the exact oppisite works great with the switch but the key doesnt work? Wonder if it would make a diffrence if the key turned /forums/images/graemlins/thinking.gif
  9. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    mine did that all of a sudden too
    I had replaced the fuse for the radio with one of those that lights up when it's blown....well, it blew, but it would only light up when you held the dash switch down. I put a regular fuse back in and it started working again /forums/images/graemlins/confused.gif
