rear power window trouble
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hoosier86, Aug 24, 2003.
  1. hoosier86
    hoosier86 Registered Member
    Nov 20, 2002
    7
    South West Indiana
    i was wondering if anyone knows how to get to the rear power window switch for an '86 K5. i put the key in and turn it, but nothing happens. i have heard that is not broken, but just that the ground for the switch is off. im not sure what the problem is. but i can't get to it to figure it out!
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    /forums/images/graemlins/thinking.gif I think the motor pulls a ground from the case, not a wire, so I don't think you have a ground issue. Did you check the fuse?
  3. hoosier86
    Nov 20, 2002
    7
    South West Indiana
    yeah fuse is ok. so i don't know what it could be
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Does the window go up or down at all? Do you hear anything when you turn the key....what does it do when you push the button on the dash?
  5. hoosier86
    Nov 20, 2002
    7
    South West Indiana
    the interior switch works but the key on the reat of the truck doesn't do anything at all. the window does even sound like it wants to move
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Sounds like you need to take the key part out of the tailgate, take it apart and clean the contact points, they are just like 60's style points in a dist. clean the contact points and reassemble, should work /forums/images/graemlins/thumb.gif
  7. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
  8. hoosier86
    Nov 20, 2002
    7
    South West Indiana
    the link was a huge success. just what i needed. thanks all of you guys for your help
  9. rawhead
    rawhead Registered Member
    Dec 6, 2002
    52
    So. California
