Rear Power Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8BaLL, Jul 8, 2002.
  1. 8BaLL
    8BaLL Registered Member
    Jun 13, 2002
    64
    Northwest Missouri
    My rear power window sucks. It has never worked properly ever since my mom bought it new in 85. We had them replace the motor a couple times when it was new and it still sucks. How hard is it to convert my power window to a manual window?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    get a suburban with barn doors. /forums/images/icons/wink.gif
  3. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    It's not hard at all. What you need is that scissor mechansism thingy that holds the window and the outside crank -- along with whatever linkages. The glass is the same, and so is the channel. Pull off that inner gate panel and from there it's pretty self expanatory. Take care when removing the locking mechanism and try to get the keys that go with the lock.
    Someone here needs to market a torque doubler for that damned motor!!
  4. 8BaLL
    Jun 13, 2002
    64
    Northwest Missouri
    The motor in mine pretty much is worthless. Like I said we have had it replaced a couple times when it was a lot newer but it never did anything. The motor works one day and other days it wont but when it does it works really really slow. My dad's buddy at the dealership said that the motor gm puts in them is too small?? anyone heard that? There should be an aftermarket motor that is larger then if that is true.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The motor isn't what makes 'em slow. There's a cable that transfers power from the motor to the window mechanism. It's like a very short speedometer cable. The grease in that cable gets gummed up and then the motor can barely turn it. Replace the cable and the window should go up and down as fast as the other windows. /forums/images/icons/cool.gif
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what do you do if all your windows are slow...my front two windows are really slow.and my rear i cant get to work at all..
    Bryan
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    For the side windows, you probably need to open up the doors and lube the window tracks really well. I use an aerosol lithium grease. /forums/images/icons/cool.gif
  8. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    My back window is the fastest of all of them. My fronts can't make it all the way up or down with out some help. I sprayed my front one's with some WD40 type stuff and it helped for a day or so now they are back to the way they were. As soon as I can get the door panels off I'm gonna clean where the wires hook into the motor and clean the track out where the rollers go. Hopefully this will help.
    James
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I've found WD40 to be useless as a lubricant. It dries up too quickly. Once you have the doors opened up, spray the window channels (down inside the doors) with white lithium grease. You can get it in a spray can that makes this an easy chore. The grease will stay there for a long time. The only thing I use WD40 for any more is removing adhesive residue and drying out a wet distributor cap. /forums/images/icons/wink.gif
