Rear Radiator
Discussion in 'The Garage' started by fourxfugly, Apr 3, 2004.
  1. fourxfugly
    fourxfugly Newbie
    Apr 3, 2004
    My Rear mounted radiator reuuses to flow water (-16 upper hose 14 ft long, 1 3/4 lower hose). Should I run a thermostat or not? /forums/images/graemlins/frown.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Welcome to CK5,
    i would hook up a thermostat. do you have it hooked up correctly, water pump hooked to lower hose on radiator, upper hose to intake? /forums/images/graemlins/dunno.gif
    fill out your profile so we know what your working on /forums/images/graemlins/waytogo.gif
  3. fourxfugly
    fourxfugly Newbie
    Apr 3, 2004
    Well, the rig I'm building with the rear radiator started life as a Blazer frame with a tube cage in place of the body (rusted off the frame!). Its now a custom framed exo cage over a Samurai body with the Blazer and 3/4 ton drivetrain(TBI 350, turbo 350, 205, d44, 14 bolt) /forums/images/graemlins/cool.gif. I've added a FlowKooler water pump and new thermostat(180 f) with a C&R 18x28 al. radiator and the water refuses to flow from the upper hose in the rear at 220 engine temp. I'm gonna change the thermostat but I'm not sure what brand/type to run. I'm also in need of a fan unit to fit the radiator and cant afford a new unit, ANY IDEAS?
