rear ratio?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ben794X4, Feb 15, 2002.
  1. ben794X4
    ben794X4 Registered Member
    Aug 29, 2001
    Boise Idaho
    How can I tell what the gears are in my rear-end??
    79 4x4 k5 stock
    3spd granny stock 350
    12 bolt open rear
    10 bolt open front
    Subvert the accepted paradigm.
  2. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    Phoenix Arizona
    Open up the cover and read the serial number stamped on the ring gear first set of numbers are serial numbers, then the last four are gear teeth and date issued.
    Looks like this
    234532324 11 41 2 87
    The 11 41 is the gear size which ='s 41 teeth on the ring gear and 11 teeth on the pinon
    divide 41 by 11 = 3.73
    If the numbers are not showing on the ring gear, you will need to elevate the tires and spin the drive shaft until they are visible
    Hope this helps, really a simple process
    If you cannot figure out the numbers post them here and we will help you out.
    Or you could always jack the end of the truck up and spin the tire, then count the number of times the drive shaft spins per one rotation of the tire.
    Taking the cover off is easier pluss you can clean it out in there with brake cleaner and change the gear oil.
    "What ever happened to my Rock N Roll?"
  3. Can Can
    Cochrane, Alberta, Canada
    Do you still have your RPO code sticker somewhere on your truck?
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
