rear ride hieght ??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tlbob, Feb 12, 2004.
  1. tlbob
    tlbob Registered Member
    Aug 22, 2003
    29
    littleton,colorado
    ok just wanted everyone opinion on this i have a 6 in sky jacker w/rear springs and the rear sits about 1.5 to 2 in lower than the front and i know this is normal but what your guy's suggestions on how the level it up add a leaf?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The only reason it is 'normal' is cuz most all spring makers spec thier spring packs to Pick-Up specs. Blazers are much heavier in the butt.
    For me I have 4" front and 5.5" rear springs and my rig sits peerty level has a slight stinkbug to it but I like it like that.
    As for you? maby ORD 1" zero rate blocks will do the trick?
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    How did you measure to find that the body doesn't sit level?
    Because the front wheel opening is much taller than the rear it often 'looks' like the back is lower when it really isn't. Measure to the body line to the ground front and rear and see how level it is. Mine looks like it is alot lower in the rear and it turned out to be 1/4" lower in the rear /forums/images/graemlins/crazy.gif
    You could also try looking for a post I made a while back on lift measurement and compair your measurements.
  4. tlbob
    Aug 22, 2003
    29
    littleton,colorado
    i dont even have to measure it you can stand back and see it the 35 have got to be tucked about 3 in more than the front the rear bumper is about 3 3/4 in lower than the front
