Rear seat belt bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BKinzey, Oct 20, 2006.
  1. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    :mad::mad::mad:
    First, Why the silly star pattern head?
    Mine won't come loose, tried soaking with Seafoam Deep Creep, heat, and broke a T-45. I also used several finer words & phrases of the English language.:eek1:
    Looks like I'm gonna have to cut & grind from underneath:rolleyes: So if I replace with grade 8 hardware they should be fine right?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am no expert , but would think grade 8 is too much . get a big boy in the backseat and maybe it wil break instead of stretching like a grade 5 :wink1:
  3. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    there is a torx socket that is called "heavy duty removal" and the design of the head-edges is different to aid in removal of stubborn bolts...
  4. dyeager535
    26,982
    191
    T45 is the wrong size for one thing.
    There's a reason they make a T47 :)
    I've busted a T47 off before, but it was a parts store cheapy. As to the reason they used the goofy sized torx, probably to try and keep people from actually removing the seatbelts, like the later anti-tamper torx holding the K5 top on.
  5. nschingeck
    nschingeck Registered Member
    Jul 12, 2006
    23
    Colorado
    Not to be a jerk off but on my 80 K5 its a t-50
  6. dyeager535
    26,982
    191
    Well, I've heard others be darn sure they were T45 as well.
    I don't know if you can cram one in there, but I know for a fact that the GM tool used in 1986 for the C/K series seat belt was a T47. It's in the manual. Not saying they didn't jump around, early on with the Torx they may have been a now common torx size, then the invention of the T47...
  7. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    A T-47:doah::(
    All I've found is T-45 and T-50.
    Haven't looked in a tool store yet, just franchise auto parts stores. Broke the no-name and the second one is a Lisle (sp?) It bent:mad:
    Maybe it is a T-50 I'm talking about. I do know I bought the wrong size at first and returned it for the one that broke.
  8. nschingeck
    Jul 12, 2006
    23
    Colorado
    I actually looked at this thread before taking out my seatbelts to remove old carpet and was unable to find a T47 as well, so i just bought the set hoping one would fit and the T50 fit snug. They probably changed something along the way.
  9. nschingeck
    Jul 12, 2006
    23
    Colorado
    I did some research on this and Dorian is absoultely right its a T47. I would imagine if they were'nt tight you could get it out with a T45 as well thats probably why people think this is the right size, as for the T50 if you go to you local sears my craftsman fit fine. There probably close enough in size thats why the T50 fit.
  10. dyeager535
    26,982
    191
    I've found T47's at Schucks/Checker/Kragen individually, (cheapies of course, but usually work) but more often than not you'll see them in a set.
  11. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i hate torx too.
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i couldnt get mine out when i tried with that stupid socket. i just herculined over them i was so pissed off with them. haha
  13. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Screw 'Em:mad::mad1::mad::mad1:
    The:hack::grind: It is!
    So back to hardware. #8? Can anyone suggest a low profile head other than a carriage bolt? Those are stupid too!:rolleyes:
  14. dyeager535
    26,982
    191
    Are they button head cap screws? (not sure on the name, that just popped into my head) I know there are allan headed bolts that look like a carriage bolt. If you hate trying to pull torx though, I'd hate to try and remove an allan stuck just as tight.
    Maybe a stud just the right length, and a nut with a built in washer. Those seem to be a bit more low profile than a standard nut. Only things I can think of.
  15. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  16. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    I had the same problem. Broke two torx bits. I ened up grinding out the bolt head from the top :grind:, and then punching them out. Much more comfortable inside then underneath.
  17. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I'll go from underneath because I've pulled everything off the frame but the body:D I'd pull the body but there isn't any space left to put it:doah:
  18. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    It's a T47. Snap-on makes a "special" torx just for the seat belt style bolts with a wider gripping edge just to get these stubborn bolts out.
  19. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    8 is fine and you can get button head bolts but they will be allen head.
