Rear seat Belt mounting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JROSS, Jan 7, 2002.
  1. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    Does anyone have any pictures of the rear seat belts showing the mounting locations and any associated brackets.
    Tha previous owner just bolted the belts through the bed and they are mounted too far foward. Thanks in advance.
    81 Blazer Silverado Package, 350, 4" lift, 35" tires
  2. dyeager535
    26,979
    IIRC, the seat belts (male ends) are bolted to the floor (ends bend 90 degrees to accomplish this) JUST behind (towards the rear of the truck) the beginning of the wheel well. In other words, the stock seat belt ends run up along the "inside" of the wheel wells, but are bolted to the floor through reinforced nuts welded to the body. No pictures, but there are no brackets. The seat belt ends are metal covered in plastic/rubber, and have a 90 degree bend at their base.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
