Rear Seat Belts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nate87k5, Sep 11, 2000.
  1. Nate87k5
    Nate87k5 Registered Member
    77
    Phoenix, AZ
    I was wondering if there was a way to put shoulder strap seat belts for the rear seat of a 87k5. I would like to do this if there is a way. Was this ever an option? Thanks
  2. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Have you thought about putting a roll-cage inside? Then you could weld the attatchment points onto the cage and bolt up the belts. Just a thought.[​IMG]
    It's not what you buy, it's what you build!
  3. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    If you found a cap and rear seat from a 90 or so K5 you would have your wish. I have an 81 with a complete 1990 interior, which means the only functional seat belt in the rear is the center lap belt.
    Hmmmmm roll cage[​IMG] good solution![​IMG]
    Rene
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I had a 88 with rear seatbelts that go over the shoulders. It was fastened on top of the cargo rimm. You know, the flat chrome plate under the window. I think it used one of the original bolts that hold the top on. Then there was a slot on each top corner on the seat the seatbelt would be guided thru. The reel was at the window bolt I think. Dont remember exactly. But maybe I helped.
    http://www.espen88k5.coloradok5.com
